Help The new rider!
Help The new rider!
I am Brand new to the forum. I have a 2006 RR with 17k miles and having issues with a few things.
Ok, I know that the first thing you might think is, Oil the chain Noob! But I think it's more then that.
I'm having issues keeping the chain tight. I'm aware of how to make the adjustments but they dont last long. (should I use Locktight on the nuts?)
Here is my other issue:
The owner I bought the bike from placed a Jardine RT-One Pipe on it. The bike rode fine for a while (3k miles) and now the Idle bounces 200 at Idle and 100 at any speed any gear.
The previous owner says (you might way to get a Power commander, that should fix it)
So, I can deal with the idle issue, But the chain will not stay tight (1/2 play) for more then 50 feet and makes alot of noise while in N, and speractically bogs the bike down (like its catching on something)
Is there a Possiblity that a Tooth has broken near the small sproket?
I hope someone has been through this and its a cheap fix. I am Beyond broke right now and it's my only form of transportation.
Thank you all for your help.
RE: Help The new rider!
Ok, Checked out the small sprocket and it seems to be fine. Below is a video of what was going on. Since then I have cleaned the chain and going to re-lube it. I hope this helps a little. I read on the forums that a chain with no play can cause a whole list of issues. The Chain guard says 1/4 play, so I'm going to try to stay a little tighter then that. AS for the chain continuing to get lose, the only thing I can think of to keep the Bolt from screwing back is some locktight. Any other help in this is appreciated.
http://www.youtube.com/v/X-4YOozVGOA
