GpPro - where to mount on 09
I got the Motorsports Hero. It has couple different arms and flat and curved surface mount as well as suction cup mount.
According to GoPro, the surface has to be clear of wax, cleaner etc to put suction cup mount. I am leaning towards sticking the mount to the bike instead of using suction cup. I read somewhere that suction cup came off on some people.
So the question is, where should I stick the mount on 09? I was thinking about right below to the side of the mirror base
Any suggestion?
Any suggestion?
Be sure to tether it somehow. You can use fishing line, inner paracord strands, safety-wire etc.
I've found for the small plastic mounts, its best to use the flatest surface possible on the fairings. Clean, stick on the mount, allow to "dry" for several hours (as directions suggest) b/f use.
I also use one of the small curved mounts on the top of my helmet...aka teletubbies style. ;-) Gives a great front view over the windscreen.
This is how mine is set up I just cleaned the area with break clean and stuck the 3m pad on and pressed firmly for a min or two. It is steady hear and you get a good feel for the angle the bike is on while recording. like I was saying if you stuck it on the windshield near the bottom it would be basicly the same as what I have.
I as thinking about getting Superbike raiser kit. https://www.motomummy.com/store/prod...d=17444&page=1
So if I do that, I think I can use one of the bar clamps they sell. Mounting on triple tree came to my mind, but I was waiting for myself to decide on raiser kit. (and still waiting) Any thought on that?
edit: I checked the triple tree now. The flat area on it is not big enough to accomodate the mounting bracket.
Yet, another edit: How about if I put the sticky mount inside top of the windscreen? It should hold right?
