gears or me
lol...
im new at riding so im not sure if its just me or bike might be having problems...today i was riding and everytime that i had to make a complete stop i will leave it on 1 gear to be ready to go...so light turns green,i use some throttle while releasing clutch,then bike will stall,engine turnoff,so i turn on again and try again to go and again stall lol,front 1 gear i go up to neutral but it seens that its not getting neutral,like it jumps from 1 to 2,so after playing with the gears for few mins ill get to go to neutral then i go to 1 gear again and after that it rides fine,but again when im on the road on like 2 gear and im about to stop i go to first,make complete stop and all this happen again,i was thinking maybe im not pulling the clutch all the way in but i dont think its that...can someone tell me if its me or maybe bike needs some adjustments? oh yea,it happens on takeoff lol..
[/align][align=right][/align]
no worries...
... yea i need to pratice more on that,but i know its goes on first when im half way on clutch,but ones i touch throttle just alittle bit it dies...only happens on complete stops,when im getting closer to stop sign and see no car i just go slow,dont make complete stop and it rides fine...
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
I'd have to agree with Justin above, take time in a parking lot and really get the feel of which part of the clutch lever movement is actually making the clutch bite. These bikes will start in first or second without too much issue if you are smooth on the clutch. If you start in second, it will likely stall a bit easier, so thatcould be a good test if you have the smoothness down.
Did you do the MSF class ? They have an excercise where you have both feet on the ground, in first gear on a flat ground, and you let out the clutch so that the bike JUST pulls forward about 3 inches, then you pull it in again. Practising this first little bit of clutch bite is what you need to do.
Good luck,
Chris.
Good luck,
Chris.
practice practice practice thats pretty much all you can do. I know when I first started riding I used stall every once in awhile too, hell I still do so some times. this probaly isn't the best thing to do but you can also try burning the clutch a little bit just don't give to much gas or you'll do a back flip and you WON'T land rubber side down.
