Front or rear sprocket?
RE: Front or rear sprocket?
ORIGINAL: woot
that and chain length.
most people I know either swap both at once or start with the rear sprocket
the front sprocket is cheaper, and I guess on most bikes you wouldn't have to remove the rear wheel, so a rearstand isn't necessary
just to clarify, sprockets don't give you any more power and they don't change the powerband or any of that crap, all it does is change the ratios at the drive chain
going with aluminum sprockets and/or 520 conversionwill gain you about .2HP by dumping a small amount of rotating mass but if somebody says they notice that on the street, they are lying
i just went one down in the front and kept my stock chain. i didnt have to remove the rear wheel. all i had to do was tighten the chain afterwards. took about 15-20min. i LOVE it.
edit: its also probably the best mod for the money. a vortex 15t front sprocket is only like $30~40
kreush33
05-21-2006 12:28 AM
