Forks feel like their sticking... any one know?
Hey guys, so I'm still awaiting shipment of the replacement parts for my 08 CBR 600rr that was involved in a hit and run. Well, I've cleaned down the bike the following 24 hours after the wreck (which was Late Friday night) and just did as much inspection I could. After I determined there was no significant engine damage, I decided to just let her hang in the garage obviously. Well the other day a pal of mine who hadn't seen the damage stopped by. I hopped on the bike just to wheel it into better light, when as I was stationary, I pressed down weight on the front breaks and noticed that somewhere on the way back up (1/3's) there was this slight "sticking" feeling I could feel through the handlebars via the forks - or at least I think somewhere in that area. I don't know how it could have happened, but I know I felt something. My friend thought it might just be a case of aftershock placebo, but I'm wondering if anyone can confirm my worries or debunk them. Thanks in advance guys!
I'm not too familiar with the 08, but rebound setting is usually found as a **** on the bottom part of your forks.. just look around. You might have something that looks like a plastic cap or you might need a flathead screwdriver. If anything, refer to your manual. I'd say set it all the way loose (basically opening up the sus fluid channels) to see if you still get that sticking then close them up to see if there's a difference..
Also remember to count the clicks so you know what settings you originally had.
