Dry sump on my RR
Old 08-25-2008, 01:08 PM
Formula Juan's Avatar
Default Dry sump on my RR
Has anyone done a dry sump system on their RR before? Does anyone know who makes dry sump systems for motorcycles? I havn't found much on the internet about aftermarket dry sump systems so i'll prolly fab up my own, but i don't have much experience at all when it comes to bulding dry sump systems.
Haha, i don't even know which types of pumps i would need. Anyone done it before??
Old 08-25-2008, 01:46 PM
shoortbuss's Avatar
Default RE: Dry sump on my RR
I don't even know what that means...doesn't really warrant me replying, but I wanna hit 1000 posts, so there ya go.
Old 08-25-2008, 01:53 PM
DuDuTzu's Avatar
ORIGINAL: shoortbuss
Old 08-25-2008, 07:42 PM
Dry sump replaces your current 'wet sump' oiling system on your engine. Right now you have an oil pan, and thats your resovoir of oil. In a dry sump system, you replace your oil pan with a pan thats very shallow. Almost literally flat and only 1 inchthick. A pan with no reasonable capacity of oil. This reduces splashing and resistance on the crankshaft. A pump is placed on this very shallow pan, into a seperate resovoir of oil. An additional pump is placed from this resovoir back into your engine.
Pro's:
- Oil starvation is non-existant. Even with less than ideal oil quality.
- You can pull more G's without risking oil starvation.
- By having an extreemly small oilpan, you can drop your engine a few inches, Lowering your Center of Gravity by up to 2.5 inches.
- Can get a few more ponies by reduced splashing of the crankshaft.
- Oil resovoir and pumps may be located such that your Polar Moment of Inertia is reduced, allowing your bike to become more "flickable" or agile.
Con's:
- Potential cost.
- Can potentially weigh a few lbs more than stock wet sump setup.
- Space can sometimes be an issue.
Old 08-25-2008, 10:26 PM
Wow, I can't say I ever have heard of that. Sounds like a lot of work, but unfortunately I am about as useful as shoortbuss on this one. You were very informative though. I would try to search our threads, but I can't say i've seen anyone do it on here. If you do end up doing it, take pics and let us now whether the gains are worth the hard work!
Edit: I did a quick search for you and found one previous thread that goes into a little more detail on why or why you may not want to do it to your bike. There was a previous thread where someone asked how to do it to their F4i I believe, but didn't receive any responses. Hopefully this helps.
https://cbrforum.com/m_219161/tm.htm
Old 08-26-2008, 10:20 AM
thx broskie
robuk
09-02-2013 03:20 AM
wooferdog
The Hurricane Saloon
07-20-2012 01:59 PM
CBRMAN99
06-19-2012 05:31 PM
Aussie Johnno
09-01-2009 10:15 AM
slmhofy
02-04-2007 09:27 PM
Quick Reply: Dry sump on my RR
