Cleaning the chain...
Old Sep 5, 2011 | 10:57 PM
MyOwnMechanic's Avatar
Default Cleaning the chain...
tomorrow afternoon. I plan on using like a 50/50 simple green n water solution (the standard simple green cleaner) and a soft bristle brush. Rinse it thoroughly after cleaning, then wipe dry.
I usually use chain wax, but this time I'm going to try switching to Dupont Chain Saver. I've heard really great things about it and wanna see how it goes.
Walmart.com: DuPont Teflon Chain Saver, 11 oz: Automotive
Does this sound like a good chain cleaning/lube method?
Old Sep 6, 2011 | 12:45 AM
sincalirider's Avatar
Best chain cleaning products are kerosene and the tirox 360 brush. Clean chain in minutes.
The dupont wax is good stuff.
Old Sep 6, 2011 | 05:30 AM
RedBaron's Avatar
kerosene and a brush or rag is the most common method, works a charm.
Old Sep 6, 2011 | 02:43 PM
yumoncbr's Avatar
August 2011 ROTM
I use the Dupont multi use chain cleaner lube thingy. I can clean and lube at same time.
Old Sep 6, 2011 | 06:24 PM
Charles_08_RR's Avatar
if you want to get crazy about it.... Kettenmax Classic.wmv - YouTube
Last edited by Charles_08_RR; Sep 6, 2011 at 06:25 PM. Reason: no mess no over spray.. but its like 70 bucks : (
Old Sep 6, 2011 | 06:32 PM
jeffjones's Avatar
lol That is way to much work.
I just use kerosene and a grunge brush and it works wonders
Old Sep 7, 2011 | 08:53 AM
So yesterday it took me about 1.5hr with simple green and a soft bristled brush to clean my chain. Previous owner hadn't done it in a while obviously. Then I used the Dupont lubricant, which went on nice, but if you get it on the side of your sprocket it leaves a yellowish haze residue you have to wipe off. Overall it looks 100x better than it did when I bought the bike. Also noticed the rear sprocket was a Vortex.
Where can you pick up just bottled kerosene? Sorry if thats a dumb question but it's not something I typically keep my eye open for. I want to try that next time.
Old Sep 7, 2011 | 03:45 PM
gotcbr's Avatar
Originally Posted by MyOwnMechanic
...Where can you pick up just bottled kerosene?...
Nice job on your chain.
You can get kerosene at HD or Lowe's, or the like.
To clean my chain, I use a GrungeBrush & wd40, followed by a wipe-down w/a red shop cloth soaked in wd40, let sit, followed by quality chain lube - such as PJ1, etc.
I do however use simple-green to clean up my wheels & swingarm when finished. ;-)
Old Oct 14, 2011 | 06:57 AM
JacksCBR's Avatar
Registered Users
Noob question alert!!!!!
I thought WD40 was bad for the chain links/o-rings. Just curious. I had my first service done recently, so it's not an issue any time soon for me. However, I went ahead and bought some of the DuPont products because I had heard they were good stuff.
Just trying to learn as much as possible! Thanks for any advice!
cbrmurphy
Nov 7, 2008 12:19 AM
quadracer18
Mar 20, 2008 11:48 AM
krash
Jan 14, 2008 09:18 PM
Opie21
May 22, 2006 03:34 PM
04CBR600
Apr 25, 2006 02:53 PM
