Checking the OIL?
Checking the OIL?
when you all check your oil looking thru the sight glass, is the bike on the sidestand? or rear stand? the reason i asked this is because of what i found out today. here are pics to compare. Pic 1 is when the bike is on sidestand, notice the oil level is just above the low level line. Pic 2 is when the the bike is on rear stand, notice the sight glass is full. Now, which one should I go when I change the oil to have the correct oil level? newbie, first bike and about to change the oil. thanks.
[IMG]local://upfiles/10637/7A3C31238A824332B2B9976C0140EEF7.jpg[/IMG]
[IMG]local://upfiles/10637/1BAC29FF17584D6F8D113FC62CA1AE5E.jpg[/IMG]
RE: Checking the OIL?
ORIGINAL: bushmasterAR15
you want the bike to be str8 or perpindicular to the ground not on the sidestand..
you had your oil changed at the dealer didn't you. Yeah they over filled mine a bit too... but yes if the bike is on both stands your seeing the correct oil line... But if it's just a little bit over I wouldn't worry. Mine has been that way for a few thousand miles now...no problems.
ORIGINAL: Doodie
just got the bike couple of months ago, and the guy said the last oil change was done @ the dealer.
