cbr air filter
Old Nov 6, 2005 | 02:10 PM
yusalisda's Avatar
Default cbr air filter
hi
just got my new bike and try to get fimiliar with all the filter so i could do it my self. i aw wondering if my cbr has an air filter, since
i cant find it in my bike. if it has, could u guys point it , wherei could find it?
thx
Old Nov 6, 2005 | 02:28 PM
Anubis's Avatar
Default RE: cbr air filter
I`m presumin you have a 600RR cos you`ve posted in here, you lift off your tank which is only a cover and underneath you will find an airbox, the lid is held on with a few screws once removed you`ll be able to see the air filters.
Old Nov 6, 2005 | 02:58 PM
yusalisda's Avatar
thank you
Old Nov 6, 2005 | 03:22 PM
Fretless33's Avatar
If it's a new bike, what do you need to get to the air filter for?
Old Nov 6, 2005 | 04:55 PM
doncollins's Avatar
Retired Administrator
When you look at the fuel tank, you're actually looking at a lot more. The cover hides the fuel cell, which is from the fuel lid back and your air box, the front half. You have to remove the seat, both inner covers (plastic that covers the top of the air ducts) and a couple bolts from the side fairing. All of this is just to see the air box. You then have to un-mount your ECU, then all of the bolts to the air box cover. And then the filter is bolted in with 3 screws. Here's a pic to help out a little.
[IMG]local://upfiles/1936/906A32FF17E94675822B90723E792B51.jpg[/IMG]
Old Nov 6, 2005 | 04:56 PM
doncollins's Avatar
the bottom picture shows the filter and the three bolts to remove it.
Old Nov 6, 2005 | 10:34 PM
yusalisda's Avatar
thank you so much for the fast repy.
Old Nov 7, 2005 | 02:24 AM
josho66's Avatar
At how many miles under normal conditions should your air filter need changed??
Old Nov 7, 2005 | 09:38 AM
Anubis's Avatar
Your manual will recomend every 12k miles but you should check it to make sure its still clean if you leave it that long, i changed mine at 8k because it was filthy.
Old Nov 7, 2005 | 09:52 AM
doncollins's Avatar
it depends on your climate and conditions. I switched out to a K&N at 3000 miles and mine old filter looked new. I ride in all weather, but we have very little dust around here. Pollen out the ..., but no dirt. Very few rural areas.
