cbr 600rr temperature
Hi ,
I just bought a 2007 , i changed the oil but i'm not sure what is the normal temperature that the bike should have. |
Mine runs consistantly at around 180 "which is where they make optimal power" however at lights or when I'm at the track I have run it hard enough to get into the LOW 200's range... at that point though I stop running it and find a cool place to park it and let it cycle until it cools down enough to shut it down.
At 220F-ish, the fan should kick in. Overheat is at 250F.
Constant movement & airflow will usually keep you under 200F. Stop and go traffic, city riding and etc will have the fan kicking on and off. |
Originally Posted by Quick6
(Post 987858)
Good lord do you really? I haven't had the 09 in the heat yet so its hard for me to comment on the 09 but my 02F4i would hang out 180's/90's when moving, and when in traffic or stop the fan would be coming on and off as Kuro said around the 220's. Never gets over 228. |
Nate my RR the fan comes on at 220ish as well. My F4i would get to 232 on a hot day in at a light. You have nothing to worry about until the temp goes over 240
