CBR 600 RR '03 engine shutting off
Hi,
My CBR 600 RR 2003 is just about 16,000KMS. Problem is after running your bike through a little traffic. When engine heats up a bit ( but not overheating), it turns off by itself. Temperature is just around 100-110 C. When this starts to happen, you will need to let the engine cool off for a few minutes/hours or so. Water reservoir is at upper level. Charging is excellent - rectifier, stator, battery has no problem.. Cooling Fan starts to operate around 100 degrees My mechanic is suggesting to flush-off the coolant from the reservoir and radiator and replace with a new one.. then see if it improves. I'm not sure if this will work but if you have any ideas, it will be great! Thanks. |
Sounds like that could be it, the coolant losing its ability to do its job. I have an 03 and noticed its a bit hotter, think I'm gonna do the same. Can you convert it to F, I'll try to remember tomarrow what mine is in degrees F at that Celcius
