Blinker wont work
Blinker wont work
I have had my bike for a week now and I just noticed today on the way to work the front leftside blinker wont work. I need help quick since I take my riding test in 5 hours and I have to have a street legal bike. I already replaced the buld and it is fine since it will work on the other side?
RE: Blinker wont work
ORIGINAL: ViperJ
Shoortbuss- Yes the back blinker works on that side. Also I switched bulbs (since the right side works) which still didn't work. So its not the bulb i guess
TheX, shoortbus well I can't really check the connector out now cause I am at work (busy at work cant you tell ). So I guess I will leave early and go home and check everything then head out to the ride test. I will let you know what happens. Although I did check the blinker fluid and it still looks full
ORIGINAL: ViperJ
I'm at work too, so don't feel bad for slacking.
ORIGINAL: shoortbuss
Ok good, cause I was gonna say blinker fluid next. Also, make sure the wire is shorting out on your exhaust bearings and that it's not cross connected with your windscreen cable.
ORIGINAL: ViperJ
Your on fire today Buss...your seriously cracking me up...
But no seriously Viper, take off the left fairing and follow the wire and make sure it isn't kinked up in a mount location (this happened in my old F4i and some electrical tape fixed it)and that the wire is intact, and check your connectors. If it all looks good, then the signal it self maybe bad. Which is probably the case if it's full of fluid...lol.
What kind of bike are we talking about and are they stock blinkers or after markets?
I googled "blinker fluid," and this is what I found...
http://www.urbandictionary.com/defin...=blinker+fluid
C Jacob W
07-29-2013 11:03 AM
