another blinker problem
Old 03-30-2010, 10:10 PM
dark_viper42's Avatar
Worked like a charm. My flush mounts blink at normal speed now. I think justin is correct in saying you can use just those block resistors. The nice thing about that relay is it covers the entire system. So if you ever added more LEDs to the rear or something then then they will already work at normal speed. Without it you would have to add more resistors I believe.
I followed this "how to". No splicing required.
http://www.600rr.net/vb/showthread.php?t=114102
GL with however you decide.
Old 03-31-2010, 11:30 PM
rrBoy600's Avatar
Originally Posted by jutsin
What ohms resistance will I need?
so it was plug n play? their website only has the 07-09's on the list of plug n play.
Old 04-01-2010, 08:31 AM
I wouldn't call it plug and play...
There is a blue wiring harness on the left side of my bike (2006) right under the upper flat fairing. The one under the left grip. You have to push two of those female connectors out of that blue harness. Remove the white connector for the harness that comes with the relay and plug them in together. I added some shrink wrap and double sided tape to attach the actual box to my bike.
The wires on my bike where red to white/green and black to gray. Took me about 30 minutes.
If you read through that thread i posted you can do it pretty easy. To me the hardest part was getting the fairings back on.
Old 04-04-2010, 01:54 PM
cwmc29's Avatar
Follow this link to fix the blinker problem. I did this to my 2003 600RR and have had no issues. Everything works great.
https://cbrforum.com/forum/how-mechanical-40/no-resistor-relay-fix-frt-rear-led-94391/
Old 04-05-2010, 08:29 AM
https://cbrforum.com/forum/showthread.php?t=94391
Same thing I did except I didn't actually cut anything. I just pushed the white/green and gray female connectors through the blue harness and plugged the relay into them. Then added shrink wrap as you did.
Old 05-10-2010, 11:05 PM
rrBoy600's Avatar
just wanted to update. I ordered the resistor from customled.com and it works great. Had to cut and splice the wires but only took me 15 minutes, best 20 bucks i ever spent. If anyone else has LED's that aren't blinking buy this!
Old 05-20-2010, 01:05 PM
danl23880's Avatar
I have posted many times but only thing i get is get a wiare diagram and it aint helping me. My problem is i bought a 2006 cbr 600 and all blinkers work perfect. Front flushmounts integrated tail and hid headlights. He has all resisitors on bike i believe. Here are my 2 problems.
1. Both blinkers do not blink at exact same pace. Left is a little quicker. Not very noticable but it is. (not to worried about it but could lead to my next problem)
2. On the main guage or cluster, the right turn signal does not work or blink to show me my turn signal is on. The left one works correctly. However i have seen the signal on the main guage go on for a few seconds and work. I no its not the guage itself, well i think it wouldnt be if i saw it go on.
PLEASE HELP
Travis_
08-31-2014 09:19 AM
tkbd33
02-21-2011 06:40 AM
oodayvidoo
06-21-2009 05:26 PM
Pearson85
06-17-2009 06:59 PM
929 FRB18
08-20-2006 11:09 PM
Quick Reply: another blinker problem
