Air pressure...
Old 05-03-2007, 04:41 PM
Shortysboy09's Avatar
Default Air pressure...
Hey guys what air pressure do you run in your rear tire?
Old 05-03-2007, 05:08 PM
Default RE: Air pressure...
35, 35is good for the street if no one is riding b!tch. 40 psi in the rear will be good if you have a passenger. keep the front at 35 all the time unless your hittin the track. cheers
Old 05-03-2007, 05:19 PM
The guy at my dealership told me to run 42lbs. I figured that was too high. Thanks for the help man and keep the rubber side down!
Old 05-04-2007, 02:25 PM
meanstrk's Avatar
42?! Talk about invitinga lowside!
Really, it depends on the tires, but those figures are good pallpark pressures. Personaly, I run 36/36 for street and 36/42 when two up on the Aprilia.. The CBR does not get used for 2 up at all.
Old 05-04-2007, 05:01 PM
aaron1085's Avatar
i run 40 in front and rear and have the stock 600RR tires... works fine for me!
Old 05-04-2007, 08:02 PM
i run around 20 in the rear. makes it all easier to keep it straight when up on one.
Old 05-05-2007, 07:10 PM
Put what psi the tire manufacturer recommends...I can't believe you guys are throwing out a bunch of pressures without even knowing what make and model tires he has...freakin' dangerous! [&:]
Old 05-05-2007, 09:46 PM
aaron1085's Avatar
41 in the rear and front says my 2004 600RR
Old 05-05-2007, 11:31 PM
ORIGINAL: aaron1085
40 in the front? thats nuts, you must have a very stiff ride. Im willing to bet that everytime you hit a pump you start having tank slaps. forget about even trying to do a stoppie/endo.
Old 05-06-2007, 05:16 AM
aaron1085's Avatar
i dont do stoppies or endos, rock on for the guys that can do them, but i cant AFFORD a crash nor do i want one... im more of a speed demon that stays on two wheels... i should revise my post, its more like 35 in the front and 40 in rear. Seems to work out fine for me.
Quick Reply: Air pressure...
