600 miles
ORIGINAL: knightslugger
Yeah, i'll get right on that...[sm=smiley24.gif] It's pretty closed minded of you to say that if you see a Mobil, or Pennzoil, or the afore mentioned Amsoil logo on a testing company's website that the whole testing is biased and is therefore invalid. You've made up you mind and wont change it, so i'm not even going to try. You'll fault it anywhere. You're just too convinced that there is no difference.
Close minded is someone who writes:
"What you will have however, is better protective oil and in a machine capable of 15,000 RPMs (3000 short of F1 cars) the more protection you can get, the better."
You know what oil they put in F1 cars...whatever oil their sponsor wants them to [&:]
I offered a real world example of a rider who has a track and street ridden CBR with over 120,000 miles on it and never had a drop of synthetic oil in it...all he did was routine maintenance and change the oil...what more do you need?
Fret, F1 teams don't put in whatever oil their sponsor tells them too, they put the decal on the car where their sponsor tells them too. that would be god damn foolish to base a million dollar engine off what your sponsor says to use, regardless of requirements. that shows a certain lack of understanding. F1 might use oil that has the viscosity of water, but it's synthetic. it needs to be. The surface tension of today's syntheitc oil protects against metal to metal contact better that conventional, and it doesn't evaporate nearly as much as dyno oils do for starters.
i'm all for an oil analysis shootout fret. I'm getting mine tested soon, are you up for it? I invite others to join in as well. the more diverse, the better.
Honda recommends "Pro Honda GN4 or HP4 (without molybdenum additives), 4-stroke oil or Honda 4-stroke oil or an equivalent motor oil viscosity SAE 10W-40..." They don't recommend using exclusively synthetic oil because your engine will blow up...why is that? If synth is so supremely good wouldn't Honda, the company who is known for making reliable motorcycles recommend putting nothing but synth in their products?
So down with Motul3000 eh? must be a **** oil because Honda doesn't recommend it... Same goes for Repsol, and Castrol, and Rotella, and Delvac... all **** because honda doesn't recommend them.
right fret?
right fret?
Synth is fine...dino is fine...both can handle anything our modest street machines can throw at them...change your oil every 3000 miles with whatever "****" oil you want and the bike will last forever.
IT'S THE OIL CHANGE THAT COUNTS...NOT THE OIL!!!
the only additive that really destroys clutches is moly
and repsol synthetic has less moly than plain jane honda gp4
done believe me
check this site
this guy sent samples to an independant tester to be checked
look under the heading for oil analysis
http://hooliganbiketech.dynup.net/ho...frameindex.htm
bottom line
have your oil tested
if the test comes back good then you could have left it in longer
if it comes back bad then you should have changed it sooner
done believe me
check this site
bottom line
yeah, ok arkansashog, sure thing...
You want to avoid energy conserving oils, not synthetics. your information is false.
Hey buddy just because you read the manual doesnt make you an expert. Good friend of mine is a motorcycle mechanic, he says NO synthetic oils and with some research you will find what I say is true. That is if yours has a wet clutch!
