2009 CBR600RR Official Euro Pictures
Honda has releasedsome details and pictures for the revised 2009 Honda CBR600RR C-ABS.
- Changes to piston, cylinder head and exhaust which lead to improved torque from 8,000-12,000rpm for increased engine flexibility and driveability
- Fairing improvements to enhance stability and reduce wind noise
- Electronically controlled Combined ABS for better braking performance along with increased safety and all-round rider confidence (optional)
- 184kg kerb weight to keep the machine the lightest in its class
Colors:
Graphite Black / Italian Red
Graphite Black / Bright Lime Green Metallic
Pearl Sunbeam White / "Tricolour" (White/Red/Blue)
Pearl Sunbeam White / Electric Blue fairing (Limited Edition)
Engine:
For 2009, changes have been made to the piston, cylinder head and muffler to increase the torque delivery in the range of revs between 8000-12000 rpm, with an impressive 3.5% increase in torque at 10,000rpm. This all-important extra "mid-range" gives improved drive out of corners both on track and on the road, increasing the flexibility of the motor and making the CBR600RR both faster and easier to ride. The engine also gets an innovative new high resistance valve lifter, specially developed for reduced surface pressure and maximum durability. This was achieved by replacing the conventional casting with a nitride compound layer plus an oil pit. The titanium exhaust has been redesigned, particularly the tailpipe and inner pipe shape. It also receives a new pop up valve system, the same as the one used in the CBR1000RR Fireblade.
Equipment:
Honda Ignition Security System (HISS)
The CBR600RR is secured by Honda's highly effective HISS anti-theft system. A fail-safe electronic interlock prevents the engine from being started with anything other than the motorcycle's two original keys. Totally disabling the engine at the very heart of its ignition system, the system cannot be bypassed by either hot-wiring the ignition or exchanging the ignition switch module.
Video: Honda’s ABS CBR600RR explained
Check out these sites for more info and pictures:
hondaitalia.com(High Res Images)
TopSpeed
MCNmotorcycle news
Colors:
Engine:
Equipment:
TopSpeed
MCNmotorcycle news
RE: 2009 CBR600RR Official Pictures
Seems like from everything I was reading, these are european models/colors...
I was told the American Honda dealer conference will be in two weeks and only then we will know what Honda is going to offer in the states.
I'm sure none of the equipment specs will change, but don't they ususally offer different color set-ups for Europe and US?
wow...it wud b european efffin colors...they always get the best color schemes! NOT FAIR!
but as ii sed in the other thread/post...the limited looks wack WITH the stickers. it makes it look to childish and sumwat BMX-ish.
take off the gayd stickers n the limited iiz a Beaut!
