2007 cbr 600rr fuel pump turns on does not start.
hello, i was wondering if anyone had suggestions for a fix.
2007 cbr 600rr I can turn the key on, turn the kill switch off, in neutral, kick stand up and the fuel pump does turn on but the bike does NOT start when pushing ignition switch. The bike DOES start when bypassing relay. I have replaced starter relay and bought new ignition switch, checked all wiring, checked all fuses, and checked with multimeter. Does anyone have any suggestions or ran into this issue? |
What did you check with multimeter and what numbers did you measure?
measure following with key ON, stop-switch=RUN 1. Power at starter-solenoid yel/red terminal when pushing start-button, volts=??? 2. Power leaving start-button when pressed, yel/res wire, volts = ??? |
