2005 RR electric fan relay
My 2005 is overheating at stoplights and when it's moving real slow, so i think the fan is not switching on, i checked the 20 amp fuse on the right side of the bike and it was good, I can't seem to locate the relay so if someone could help me out that would be great, also any other ideas of what could be wrong. Just to double check these bikes only have 1 fan correct? The reason i ask is because my R6 has two... Thanks in advance
- does it sound like its coming on around 220F?
- has the bike ever been down? when i crashed mine on the track the fan got bumped up against the radiator to where the fan wouldn't spin, but all the electrical components were fine, it just needed to be bent off of the fan, try spinning the fan, if it spins freely, then its not bumping the radiator
- have you checked if the male or female 2 prong plug is corroded that comes off the fan? sometimes they need to be sanded a little to get the corrosion off
muckdawg24
09-17-2007 12:13 PM
