2003 cbr600rr ignition problem.
Old 01-31-2018, 08:22 AM
Default 2003 cbr600rr ignition problem.
Hey guys. So I have an issue. I got some new bars and switched them out on my cbr, pretty easy deal. Just pulled the stock ones and put these on. And I got everything hooked back up and back on the bars, but now my bike wonít start. It doesnít crank either. And when you turn the key the fuel pump also does not prime. I want to say that the lights should come on when you just turn the bike on. Iím pretty sure they did but I could be wrong. Either way my headlights arenít working either. They may once the bike starts. However my blinkers horn and rear brake lights work fine. The front brake doesnít light up when you pull it. And of course the ignition button doesnít do anything. No sounds, nothing. Everything was working perfectly before. I pulled everything back off and all the wires and internals look fine. I donít see how anything could have messed up. I didnít try and start the bike before it was all put back together. Any suggestions? Thanks
Old 02-01-2018, 06:33 AM
CaBaRet's Avatar
Hi matey sorry no one has got to you yet, so here goes, what I would do is take off everything again except the Ignition switch, bypass the other switches on the bars and put they back on one at a time (clutch switch, stop switch and bypass the BAS while your at it) make sure all connections and fuses are valid and try again,hopefully narrow it down
Old 02-01-2018, 10:16 AM
Thanks. I will try.
I have checked all the fuses and connections. And relays. They are all fine. And everything seems to have good continuity. My next step is to try disabling the tip sensor. Mayhaps it thinks the bike was wrecked when the bars were taken off. Past that I do not know. All my lights work. My fuel pump just doesnít prime and the ignition wonít turn the engine.
Old 02-01-2018, 10:24 AM
CaBaRet's Avatar
Yes it will be something simple as they were working beforehand
Old 02-01-2018, 10:46 AM
Yes. They were working perfectly.
So I will try that and go back through my wires as well. Past that I may have to take it to someone. I hope not. I can only assume that will cost me a lot of money
Old 02-01-2018, 10:54 AM
CaBaRet's Avatar
Don't think you will need to do that, its just a matter of going through the faults methodically, it wont be a problem
Old 02-01-2018, 11:23 AM
I hope so. I canít imagine itís anything major. Iíll probably find it and laugh at myself because itís so trivial. Thatís what has me so worked up over it haha
anyway thank you. I will go back through
sargentpopo
10-11-2012 09:47 AM
cravenmohed2k
06-07-2011 01:13 PM
dustinj
11-07-2010 12:17 AM
CBRManRR
04-04-2008 08:47 AM
Quick Reply: 2003 cbr600rr ignition problem.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
