2003- 600rr headlight mist
I realised that when driving the bike for example a 30min ride and then switch it off & park after a couple of minutes a kind of mist start taking place inside the headlight! To my knowledge it's beacuse the inside of the headlight is hot coz of the heat of the bulb and the outside temperature is a bit cold! My question is here: Is there anyone encountering this problem? All 2003 models have the same prob or there is something wrong with mine?
I gots an 03, no mist..its prolly condensation, are your rubber gasket things totally sealed against the asembly?? are you swimming with your bike? I dunno..if its not broken, break it already...
ya when i had my 03 i didnt have that problem either?? well not that i noticed anyways??
It is condensation prob not mist..I check for rubber seals if they are perfectly attached. This bike has never seen a drop of rain or water (except when washing), never used it on wet roads etc... Tough it's 2003 it only has 6000kms on the odometer, used only as a sunday bike...
| All times are GMT -5. The time now is 03:29 AM. |
