08 RR front turn signal lights HELP!
I'll try to describe this as clear as I can. I got an 08 CBR 600RR. I removed the missle launchers up front with smaller LED lights. For the stock lights they have the 3 wires (running lights, turn signals and ground) for the LED they have two wires (hot and ground) I hooked the turn and running lights to the hot wire and then ground to ground. The turn lights up top (don't know the tech. name, the ones that blink to let the rider know the lights are turned on) stay on, and all 4 lights around the bike wereon bright. I called the maker and they told me to put a8ohm resistors on the hot wires. reading on the forums i keep hearing resistorsare bad and to go with the http://www.cyclegear.com/spgm.cfm?L1...G&tier2=14just curious if anyone else had thesame problem and if the Turn Signal Equalizer worked and solved the problem. Please some help! need to get this fix asap got pulled over twice due the lights staying on all the time it burnt out my turn signals on the back. and i don't think saying i am on my way to get them looked at now will work everytime. thanks for ANY help or input! THANKS
RE: 08 RR front turn signal lights HELP!
https://cbrforum.com/m_129799/mpage_2/key_/tm.htm You need to only use the turn signal or buy diodes and solder them in so you will have your running lights and your turnsignals your running lights are back feeding into the turnsignal circuit thats why your turn signals are staying on . buy the doides at radio shack there is a thread on here to tell you how to do it
