07 won't start
07 won't start
I rode to work this morning just fine. Then I rode to go work out and then home to take a shower. When it was time to go back to work, I rolled back from the house and no go. It powered up fine, I couldn't hear the fuel pump prime but I had my helmet on and couldn't really hear too well, but anyway, the starter just kept turning and turning to no avail.
To clear up the "are you a dumbass" questions: Yes, the key was on, yes it has gas, yes the kill switch was in the run position, no it hadn't been tipped over, yes I tried it in neutral and in gear.
Any tips or questions please ask, I'm at work now, but will be troubleshooting as soon as I get home. Thanks for your help in advance.
open your gas cap do you hear a pressure release like a slight hisss...?
could be when playing with teh plastics you pinched a ventline... causing a vapor lock ..
check that .. then all the plugs around the mid bike... especially the fuel pump plug make sure when you were doing whatever you were doing that you did not pull on wires and pull a plug
No, I haven't had any plastics off since I put on my frame sliders early this year. And I've never had the tank off or lifted. But it did it again yesterday. I was sitting at a light and my friend that I was riding with hit my kill switch just being a dick, and it wouldn't start. I had to pull over to the side and let it sit a minute and it started right up. I just want to know where to start looking for something wrong.
