'04rr. help changing the oil!!
RE: '04rr. help changing the oil!!
I've never worked on a '04 but I have an 03 RR...they should be the same. You should be able to see the drain plug if you get on ur belly. It should be in the open space where the two lower fairings come together. You'll need to take off both lower fairings and the right side mid fairing. You'll also have to unbolt the coolant reserve tank, which is behind the right side mid fairing,in order to get to the oil filter. Take some aluminum foil, form a channel with it and put it on the header pipes...that way when you take the oil filter off, you won't leak oil all over your pipes...hope this helps
dude no offense but you obviously need to check out the owners manual.....not to mention the drain plug on almost any vehicle is located on the oil pan which would be directly under the engine. If you do not already know this maybe you should have someone change it for you as not to screw anything up....just my 2 cents i dont know you personally but you dont sound experianced (at all)
filter is located behind headers. plug is located under neath the engine ( on the oil pan where everyother drain plug made is located [sm=smiley24.gif]) you do not have to remove the fairings to change the oil. i would suggest getting a oil filter wrench with a adjustable rubber band thingie to get it of, its the best kinda i have used on a bike.
