04 to 05 outer clutch basket
Old Yesterday | 07:11 PM
RGV250F3's Avatar
Default 04 to 05 outer clutch basket
New member here, can anyone confirm if the 03-04 CBR600RR outer clutch basket is compatible with 05-06 CBR600RR? I finally tracked down a rattle/buzz noise to the outer baskets springs being sloppy loose on my 2005 .. but 05-06 outer baskets are no longer available..
File Type: mov
Old Today | 05:33 AM
They have the same part number so should be compatible.
https://www.partzilla.com/catalog/ho...600rr-a/clutch
Old Today | 09:29 AM
RGV250F3's Avatar
According to Partzilla, both are discontinued… bummer.. part numbers are slightly different that’s why ai was trying to figure out, Is it just a superseded part number which happens commonly, but are they identical, except the last three digits of both numbers. I guess it doesn’t matter, used is the only option.
2004 22100-MEE-000
2005
22100-MEE-D00
Old Today | 09:47 AM
Good spot, didn't notice the 'D'
CSML normally indicates superseded parts and also 'used on other models'
https://www.cmsnl.com/en-gb/honda-cb...patible-models
In this instance it does not state that they are compatible, so it does not look like it unfortunately.
Yep looks like it is used for you...
Old Today | 10:57 AM
I have done a bit more research and 'captain google' and many other sites indicate that the last 3 digits are revisions to the part, so 'might' be ok
A typical Honda part number breaks down as follows:
1. Part Type & Function (The First 5 Digits)
These five digits identify the specific component category or system. [1, 2]
  • Example:
    Code:
    15410
    designates an oil filter,
    Code:
    28300
    is for a kickstarter, and
    Code:
    44301
    relates to an axle.
  • If the first five numbers match between two different bikes, the part is highly likely to be identical or interchangeable, which is a great tip for finding replacements.
2. The Model/Engineering Code (The Middle 3 Digits)
This section (often containing letters) indicates the original model or vehicle series the part was developed for. [1, 2]
  • Example:
    Code:
    KPH
    might indicate a CB125F, while
    Code:
    MEB
    represents a CRF450.
  • Note: Many older, universal parts (like general seals or fasteners) were originally designed for early models but are shared across dozens of different bikes.
3. Revision or Color Code (The Last 3-4 Digits/Letters)
This portion signifies modifications, different suppliers, or specific colorways.
Gboss
How-To: Mechanical
Oct 23, 2016 06:36 PM
subyman1440
Mar 17, 2015 07:25 AM
keane187
Jan 20, 2008 06:25 PM
f4ikid05
Jun 16, 2007 01:10 AM
Pilot Powers
May 30, 2006 02:06 PM
