03 Turn signals dont blink
So I got these flush mount turn signals and I was reading other threads about the correct way to install them and i ended up doing it this way...https://cbrforum.com/forum/how-mechanical-40/convert-2-wire-signals-3-wire-inputs-84998/ After i did all of this splicing and soldering the runnings lights work but when i go to switch to the turn signals they just blink at a very high rate of speed, hardly even noticeable.The diodes are facing the right way and i did everything else correct.
I tried just hooking up the turn signal to the corresponding turn signal wire on the bike and also just connecting the ground to see if i even got any blinking that way, and of course that didnt work either.I checked the turn signal fuse and it seems to be in tact.Could it be a turn signal relay?Idk... Im stumped and need some help please.Thanks.
on
1 Post
IIRC, the diodes are only there to make the 2 wire lights function as 3 wires.... so if they light up when the ignition is on (or the bike is running), and if they flash when the directionals are on, then the diodes are working correctly.. to slow the flash rate, you either need resistors or you can replace the flasher with one made for LEDs..
If I am incorrect, someone please correct me!
Adam
Adam
on
1 Post
plugging in a new flasher is helluva lot easier than cutting and soldering in diodes....
It will be as difficult as getting to your flasher..
Here are some videos of the install on a few RRs..
http://www.youtube.com/watch?v=1f8CxS9Cf9s
http://www.youtube.com/watch?v=q6AxdaICrek
http://www.youtube.com/watch?v=xVMFRHi8dLw
I have an F4.. so I am no expert on your bike.. see if one of those setups matches yours..
Hcstreetriding
04-27-2008 03:31 AM
Ocelaris
11-06-2006 03:44 PM
