03 electrical starting problem when hot
Old Apr 29, 2010 | 01:56 PM
pablohoney's Avatar
Default 03 electrical starting problem when hot
Hi,
I got this bike last week and I love it but when I stop to get gas o run into the store an just leave the bike stopped for a minute I won't really start back up. When I turn on the ignition it looks fine but when I push the starter it turns over for a half second before resetting. I can push start it easily but it is a pain in the ***. It also starts up just fine when cold. No signs of dead battery. The po mentioned the rectifier. Think I just need a new rectifier? Thanks
Old Apr 30, 2010 | 10:31 PM
pablohoney's Avatar
Anyone? Help?
Old Apr 30, 2010 | 10:52 PM
Kuroshio's Avatar
Download ElectroSport's Motorcycle Electrical Fault Finding Chart (PDF)
If you don't have the manual, that will help you to test the charging system. It's a good general diag flow chart.
Old May 2, 2010 | 11:39 PM
pablohoney's Avatar
Thanks for that diagram definitely going to hold on to it.
Old May 10, 2010 | 05:16 PM
pablohoney's Avatar
I replaced the rectifier with a new one and now When I turn on the ignition the lights go on and the blinkers work and everything is bright, but the horn just gives a tiny squeek and the starter won't turn over, it just makes a slight sound and then it all resets. When I push start it, it runs with no trouble.
I also checked the voltage leakage with the rectifier disconnected and it showed .2 then .3 then .4 then 0 and stayed there. This all happened with in a couple of seconds. What does it mean?
Thanks
Old May 11, 2010 | 11:52 PM
pablohoney's Avatar
Charged the battery and all is well.
Old May 12, 2010 | 12:09 AM
Kuroshio's Avatar
Congrats
kwood
Jun 1, 2020 09:53 AM
15ura
Sep 9, 2012 05:07 AM
Preid
F2 Tech
Apr 11, 2010 05:26 PM
michaelsbt
May 13, 2009 09:20 PM
zer0gh0st
Nov 26, 2007 09:07 PM
