UK spec CBR600F4 - MPH per 1000rpm in 6th?
I wouldn't think that the US spec would be different from the UK.
sccbr600 - thanks - that means that the gearing is around 12.5mph per 1000rpm in top.
So 70 divide by 12.5 = 5600
kilgoretrout - thanks - nice site.
It says that at 70 mph the F4 should be doing 5500
So 12.73mph per 1000rpm in top.
Both agree within 100rpm so looks good to me.
SO - Any idea why a speedo on an F4 would read low ?
Bike rides very well - pulls cleanly and reaches red line so I belive the tachometer.
Sprockets are the standard 16F and 45R
Rear wheel has a 180/55R17 on it.
However at 7000 rpm in top it is only showing 60mph.
UPDATE.
Had a good dig around the bike and found some slightly corroded connectors.
Will be cleaning the connectors in next couple of days.
Whils I was checking the connectors I noticed a box that is not on the wiring diagram.
The box is in the line fron the speed sensor on the gearbox to the wiring loom.
It is all black with no markinga on it - honda male and female plugs on each end so the loom plugs in to it.
Has anyone else got this small black box fitted or is it possible that a speedo healer has been fitted at some point ?
UPDATE - pulled all connectors apart and cleaned those that needed it.
Put ACF50 on all the connectors before plugging them back together.
left the unknown black box out of the loom
Speedo vs RPM in each gear now matches what the book says it should so all sorted.
To confirm - I Plugged the black box in again and speedo reads low.
I assume it is some kind of speedo healer but it must be pre-set because there is no way to calibrate it on the bike.
