turbo f4 need help
turbo f4 need help
yes i said turbo f4!i know ,why turbo a 600 just buy a bigger bike. well i had the bike and i had the turbo so whynot?i will post some pictures as soon as i get battries for my camera.i have the down pipe fabed up and the turbo mounted.i need to run some oil lines to the turbo.thats where i need your guys help.i can put the return back into the oilpan.anybody get any idea where to get the oil from? by the way the turbo is an ihi off of a wrx
RE: turbo f4 need help
ok just looked again under a different section and found it. Its on the back of the block appears to be above the clutch cover. Im sure if you pull of the right fairing you can find it. go to hondaparts-direct.com into the parts finder. put in the year and model and look at the crankcase diagram, zoom in and its number seven
