Throttle Cable Settings
Old May 16, 2013 | 01:57 PM
katt72's Avatar
Question Throttle Cable Settings
On my F4 the throttle don't return to de-throttle position. Can anyone tell how the throttle adjustment screws are set. Does the top throttle cable setting is all the way out or in? What is the bottom throttle cable set as?
Old May 16, 2013 | 03:20 PM
CJardine's Avatar
Track junkie & modaholic
Are they clean? If its sluggish than they are probably dirty, if the grip just stops than you need to take off your tank and adjust the cables from there. You need to adjust the cables so there is between 2-6mm of free play at the throttle grip.
Old May 17, 2013 | 09:11 PM
Fobwareagle's Avatar
Also check that the throttle tube isn't being held up by the grip rotating in contacr with the bar end. Grips come in different lengths and sometimes they're to long for the throttle tube.
airforce123
Apr 4, 2012 10:24 PM
cbr6rider
Apr 20, 2011 08:57 AM
some guy #2
May 3, 2008 08:33 PM
283racin
Apr 30, 2008 11:16 PM
