Stalling when Hot Issues Continue!
i have the same problem with my 2000 f4. also wondering if anyone can help with my other problem. started my bike with the choke open like you should. my bikes run at about 3 grand with choke open. left it running for about 10-15 mins like and that cuz i went into the house to grab my gear. came back and there was what i think to be coolant on the floor from my bike, and the oil light was on and was over heating. the coolant looked kinda dark so i dont know if there was oil in the coolant or not. took the plastics off the next day and found there was a whole in the coolant res. is that all it was or did the head gasket blow.
Alright guys - I wanna see if a bunch of are actually having the same problem. I've got an easy way to test it, but I need some of you that are having the stuttering issue once got to test something. After riding your bike home from work or something and your bike is stuttering, pull your seat and rear fairing off and check the voltage on the black/white wire on this (see pic below) relay (there are 2 black/white wires - either will work). Report your voltages back here. I'm getting ~10v and it drops to around 7v when the fuel pump kicks on. Let me know what your voltages are so I know we're all having the same issue.
My voltages:
12.49 & 11.88 on the Black/White wires on that relay.
I unplugged that relay and added some dielectric grease to the plug and hooked it back up, actually did that to all of the relays and the plug for the fuel pump. My bike acted like all was well and nothing was wrong. It idles fine with no issues, the fan even kicked on and off with no stuttering or stalling.
I had planned to clean my carbs but haven't yet so I set the tank back on the bike, connected the fuel line, and hooked the fuel reserve sensor back up to get the voltages requested. But when I hooked the fuel reserve sensor back up on the tank I swapped the positions of the wires. My sensor's prongs are more or less oriented front to rear. I did have the green/black on the front prong and the brown/black on the rear prong. Now they are reversed.
Seems my problem is gone.
But we will see if it stays away.
