Some help please
Some help please
So I started my 99 cbr f4 today on half choke. Let it run and got involved in something. So I let it run for like 20 mins at 2k. I know. Stupid. I meant to come right back out and my kid needed something. SoI come out and there was a nice size fluid spot. So I shut it down quick and it was hot as *****.
Had a friend come down and take a look and I actually didnt lose as much oil as I though. Not even a quarter of a quart cause it is still full. So I figured it spit it out through the breather valve. The spot was under the center of the bike and did not get on the header or gather in the fairing. It was not coming from the oil pan or the oil filter.
So I dont know where the breather valve actually is. I fired it back up when I saw the oil was full and let it run normal and it was not leaking so that is why I came to that conclusion.
Where can I locate the breather valve to check? Havent pulled the fairings yet.
Thanks in advance. No need to scold me. I know it was stupid but when the kids need something you totally forget about things., Its crazy
RE: Some help please
I did the exact same thing at the end of last year, my daughter wanted somethign to drink, and i forgot my bike was running full choke for about 10 mins! came out and the temp needle was up in the red, shut it off and I hear the coolant boiling, and about that time it all comes spilling out. burnt a hole in the side of the overflow reservoir.
Im not exactly sure where the breather valve is, havent pulled my fairings in a few months. but I would get them pulled off and the tank and you should be able to spot it.
ORIGINAL: woot
That is probably coolant, and not oil... if it was oil it could have been stuff that was stuck on the case and got hot enough to run off.
Check the coolant overflow bottle is still in range... and next time don't start it until you're ready to go
