runs very hot
runs very hot
I just bought a 2000 f4 and it was running all the way up to the red line on the temp guage. I checked and noticed that the fan wasnt working. I grounded it out so it runs all the time but i still am running about a centimeter from the red overheat line. I have the proper amount of oil, no blown head gaskets or exhaust leaks. Plenty or rad. fluid in my overflow. I cannot seem to figure it out. Any help is appreciated
RE: runs very hot
Dude, I would assume your coolant isn't working. I would totally drain your coolant, take off the thermostat, install a new one, and fill the fluid all the way up. It may not fix it but that's where I would start, thinking the thermostat is stuck closed or clogged.
Good luck!
Good luck!
