Removing ignition switch
Old Aug 13, 2013 | 03:36 PM
Lisandro's Avatar
Default Removing ignition switch
Hi guys,
I have bought a blank key to have another copy.
Also, my steering lock - sorry about my english- was not working properly, was kind of hard, so I`ve talked with a blacksmith and he told me to pull out the ignition switch to solve both issues.
After disassembling all the front part of the bike, I have found that the bolts holding the ignition switch were "weird". I have tried with a torx t40 but didn't work.
Don`t you know if those bolts before were torx t40 and somebody tried to unscrew them with other tool and broke them, or it`s necessary a special Honda tool to pull them out??
Thank you in advance!
Your south american friend
Old Aug 13, 2013 | 04:07 PM
74demon's Avatar
They are security bolts. The heads are designed to break off on installation.
To get them out, you need to use a punch and a hammer to knock them loose. Once the start to turn, they will back out easily.
Old Aug 13, 2013 | 04:33 PM
Lisandro's Avatar
Thank you bro!!
How do I replace them? Any kind of bolt that just fits?
Thank you!!
Old Aug 13, 2013 | 04:41 PM
74demon's Avatar
A correct allen bolt will work, but will not be as "anti-theft" as the original bolts. The security bolts are preferred, but its up to you.
Turbulenz
Jan 15, 2012 04:23 PM
IceGT
Jul 19, 2011 01:31 PM
__Z__
Oct 18, 2010 02:03 PM
batman4114
May 15, 2010 02:07 PM
Frostino
Sep 15, 2005 12:50 PM
