Rectifier / Regulator went kaput
Hey fellas just did some testing and found my rectifier regulator went bad...
as most of ya'll know I like to mod so what other's can fit on the bike
also if you guys want a nice after market ones which I may wind up getting
check theses guys out
ElectroSport - Motorcycle, Dirt Bike and ATV - OEM Quality Stators, Regulator/rectifiers and CDIs
Sorry your R/R died. It happens. ;-)
I've recommended the ElectroSport unit b/f as an aftermarket replacement, if you want to go that route. From others I know that have used it, its performed well.
As I'm sure you've seen from my previous posts on the R/R, Honda revised & redesigned the R/R & it supersedes the old flat model. The new version is finned & is the only version you can order via Honda Parts..
Since I installed my new factory finned version R/R years ago, its worked perfectly. I relocated the R/R position to the Left side of the bike's subframe, where the F4i model has it located. My R/R is on its own on the left side & gets plenty of airflow.
^ gotcbr recommended the electrosport r/r when i opened a thread earlier. I ordered one but when I installed it, it was overcharging my battery. Putting out about 18.5v it boiled the acid in my new battery when i went for the first ride . I sent it back and am currently waiting on a replacement which I will be testing this time before I ride.
Just a FYI really. I have heard good things about their r/r's. Maybe I just have crappy luck.
FWIW, I always recommend the new revised finned factory Honda unit R/R over anything else first.
99cbrf4600, I went back thru your posts & found this...https://cbrforum.com/forum/cbr-600f4...stions-140684/. Myself & Turbulenz both recommended the new finned unit from Honda as replacement.
Also, I recommended getting a good quality battery such as the Yuasa. I mentioned that I didn't care for Walmart batteries. <-That may be part of your bike's issue. I've personally experienced issues w/ Walmart batteries & they were more trouble than what they were worth.
Nevertheless, hope you get your bike's issues sorted quickly.
when i installed a brand new stator, r/r and battery, for extra reliability i straight wired the three stator wires (did away with connector and soldered then shrink tubed them), also, i straight wired the r/r posi and neg to the battery with a 30 amp inline fuse on the posi side (carry extra fuses). then i strapped a cpu fan on top of the r/r to help keep it cool. (posi side to the rear running lights and neg to frame) after that i hooked up a koso digital volt meter to be able to monitor my charging system at all times, so i will know when my charging system is acting up before it fries expensive parts and leaves me stranded.
since i did this the voltage stays at 14.5, in hot weather, even at idle. i keep a extra r/r, mini solder torch, solder, 12 ft roll of wire, female and eye butt-end connectors, fuses, diodes, wire brush and wire strippers under my seat at all times....why? getting stranded out in the middle of no where in the mountains by yourself really, really, sucks.
