rear bike lift $40
rear bike lift $40
harbor freight has a rear bike stand for 40.00 it has the flat pieces not the spool lifts. but they have a all aluminum the has the spool lifts and the have the adapter for the lifts to fit the front forks 2. i went by one today and saw it. seems just as good quailty as the rest that i have seen. i didn't have the cash on me when i went so i'm going back tomorrow to get it.
the black stand
http://www.harborfreight.com/cpi/cta...emnumber=66192
the fork adapters
http://www.harborfreight.com/cpi/cta...emnumber=65621
the aluminum one
http://www.harborfreight.com/cpi/cta...emnumber=99701
there website says the have the spools to but i didnt see them at my local store
the black stand
the fork adapters
the aluminum one
great product
I bought the black one about a month ago. It works great. I have used it to change the spark plugs, air filter, remove the tank, install an undertail, adjust front/rear brakes and adjust/clean the chain.
The front fork adapters work very well. If you do purchase the front fork adapters and plan on swapping back and forth, then do the following:
Extend the rear adapters inward until they are both even and lift the rear securely. Take some electrical tape and wrap each adapter closest to the inside of the lift. Repeat the following for the front adapters. This will allow you to quickly swap the adapters without guessing how far to extend them inward each time.
My only regret is not buying two of these to lift the entire bike off the ground.
