Rattle noise from engine
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
I have a cbr 600 f4, 1999 with only 10,000 miles on. When you rev the engine there is a rattle from the r/h side of the engine.
I think this is down to the cam chain tensioner as HONDA'S ARE PRONE TO CAM CHAIN RATTLE.
Anyone know roughly how much it would cost to fix problem at a garage.
Thanxs
Thanxs
It is an easy fix.
IF you have any mechanical know how you can have it done in an hour or less
Here is the a site that gives you step by step instructions: http://www.bossturbo.com/cbr/howto_cct.shtml
The part oem will cost you about 45 and 3 for the seal.
Good luck
Good luck
Go to this web site and and there is a easy fix that Uncle Jeff has come up with.Here it is
CBRWorld.net - OEM CCT MODIFICATION PIC'S he seem to know what he is talking about he has wrote alot on the bb noise check it out and let me know what you think I am going to try it.
It is an easy fix.
Good luck
Good luck
![Frown](https://cbrforum.com/forum/images/smilies/frown.gif)
also i get something of a noise likethis but it only happens around 5,000rpms. any idea if this is the same thing?
