Radiator Compatibility
I found a Radiator on ebay for $200. Looks like its in good condition. But it says that its for CBR models 2002-2005 or something. Would be compatible with the 2000 year od CBR's? Heres the link. I need to know as soon as possible so I can take this offer up.
http://cgi.ebay.com/ebaymotors/CBR-6...mZ220292033110
RE: Radiator Compatibility
If i recall as I have both bikes but havent tried swapping parts, the F4i only has 2 bolts one on the bottom and one on the top, the one side has a bolt hole but the f4i has a pin that slide into it for alignment. I'm pretty sure my F4 actually has 3 bolts in those same places. Im pretty sure you will have no problem.
f4 radiator only has 2 bolts and the right side hole tab on the top of the radiator is for a pin that hangs off the frame.
Again, 2 bolts for the radiator but 3 actual mounting spots.
99.999% sure they are identical but if you want to check go to bike bandit.com and just look up part numbers and cross reference them.
2008, cbr, compatable, compatiable, compatibility, compatible, cross, f4, f4i, honda, r1, radiator, radiators, referance, yamaha
