Preferred Bar Ends?
bringing this back up.. I might go with the delrin ones off ebay listed above.. but I am wondering how much it matters regarding the strength of the bar end bolts? They are hex head, but they arent listed as hardened.. the ebay seller didn't know the strength rating.. should I be worried at all or would something like hjust a standard zinc coated or grade 5 with some blue loctite be fine? I would rahter save money on the bar ends to buy some vortex frame sliders...
Thanks
Adam
Thanks
Adam
on
1 Post
oops.. I meant "they are allen head". hex head sounds more like a standard bolt.
They seem a little larger compared to teh ones that I took off .. they okay?
The part of the bar end that sticks out of the handlebar measures 1-1/2" long, and 1-1/4" in diameter. The part that goes inside the handlebar measures 1/2" long, with a slot on half of the last section which mates with the insert (as seen in the second picture). The Silver Zinc plated steel bolt is 6mm in diameter.
should be fine, the stockers I took off mine just had a phillips head, so I like the allen alot better lol
