oil suggestions
Old May 26, 2011 | 11:16 PM
93MitsuVR4's Avatar
Default oil suggestions
hey guys this might be a noob kind of question but i was wondering what kind of oil i should get for my 1999 cbr 600.. And how much do I use?
I googled it and some one says to use 3.2L of 10W40
Also what size oil filter do i use?
Thanks
Casey
Old May 27, 2011 | 01:07 AM
stampern's Avatar
I use the Honda oil filter - I get mine at the honda dealership. I also run the Honda Gold oil. It's a little spendy, but I figure it's worth it in the end. The CBR has a wet clutch so it needs a special oil (I think it's with moly) that our bikes need. Somebody correct me if that's wrong. I don't have my oil bottle in front of me. And I remember it being around 3 quarts of oil. I haven't done one on my bike in 2 years cause it's been in restore mode.
Old May 27, 2011 | 01:13 AM
asides's Avatar
rotella t6 many people luv this stuff do a sreach about it. or just go get some honda oil just make sure its not car oil u dont want molly not good for your clutch.
Old May 27, 2011 | 02:42 PM
gotcbr's Avatar
There are many opinions on oil in various threads here on the forum.
In short, Honda GN4 10W40 or Shell Rotella T 15W40 are sufficient. Rotella is available at most any Walmart in quarts or 1 gal jugs.
For Reference, check the Honda factory service manual (links available here on the forum) for oil capacity, its in Section 4. Shows: 3.2qt for drain & fill only..3.5qt for drain & filter change.
Following the proper procedure for changing the oil & filter for your bike, you'll want the oil level to fall at or just below the oil fill line window.
Oil filter: Honda 15410-MFJ-D01. You can use various aftermarket filters as well, such as K&N, Purolator, et
Old May 27, 2011 | 04:19 PM
polish man's Avatar
i use rotella 15w40 cause i get it free and ive seen lots of others recommend it so that helps. i use a napa oil filter
Old May 27, 2011 | 09:53 PM
93MitsuVR4's Avatar
hey guys thanks for the help, im gonna go pick up some oil and a filter on tuesday..
Old May 27, 2011 | 10:53 PM
BBirish's Avatar
i use a honda filter and just to try it i used repsol sport 10 40 last oil change and i feel like the motor runs better, smoother, maybe its just me...stuff is expensive though
Old May 27, 2011 | 11:55 PM
gotcbr's Avatar
You're welcome. Hope your oil & filter change go well.
BBirish,
I've used Repsol 4T Synthetic for track. You're not kidding about the price!!! :O
Old May 28, 2011 | 03:04 AM
PyROphantasie's Avatar
What's the difference between 10W40 and 15W40? Also i was looking at the Rotella and it says it's for Diesel engines?
Old May 28, 2011 | 01:25 PM
gotcbr's Avatar
There are extensive discussions here on the forum regarding Rotella. Do a few searches & you'll find 'em.
