Motorcycle back firing on acceleration? What to do?
Old 02-08-2011, 09:46 PM
jnyguam's Avatar
Question Motorcycle back firing on acceleration? What to do?
When i hit around 6-10 rpm in gear it starts to backfire. It hasnt done this before.
Started bike with choke, its cold outside.
Waited less than a minute and then it idled fine
took off down the road it was actin up a bit. pulled off to the gass station
bought a 5 hour energy and took a ****.
then i went back home.
35000 miles on the engine (rebuilt)(carbs).
What do i do to fix this problem?
Valve adj.?
clean carbs?
Ebay?
all of the above?
Old 02-09-2011, 02:28 PM
jnyguam's Avatar
It acts fine after the engine warms up a bit, but when i hit around 10-14 rpm it will do the same thing.
Old 02-10-2011, 02:19 AM
Denfrosnesko's Avatar
Perhaps it is running too rich? What color is the back of your exhaust?
White/light grey = too lean, which is very bad
black = too rich
Dark grey = perfect
Old 02-10-2011, 03:56 PM
jnyguam's Avatar
Thumbs up
black, thanks for the info. Im gunna look around forums to see if i can find a solution
Old 02-11-2011, 02:25 AM
I use this to adjust my fuel mixture
http://www.gadgetjq.com/ctune.htm
Hootie233
06-11-2010 03:09 AM
jonnym61
03-09-2010 09:26 AM
otello
02-25-2009 06:11 AM
Nkostel
07-03-2007 10:43 PM
socket
05-25-2006 01:54 AM
Quick Reply: Motorcycle back firing on acceleration? What to do?
