leaking coolant
Old 07-02-2011, 04:12 PM
kapsiak's Avatar
Default leaking coolant
i bought a 2000 cbr f4 3 days ago. rode the bike twice. the third time i went to ride it i started with the choke open and left it run about 10 mins. my bike idles around 3 grand with choke all the way open. when i came back to ride the bike there was what i think to be coolant under my bike. i dont know if it was just dirty coolant cuz the guy had the bike never changed it or if it was oil/coolant mix. the next day i off the plastics and saw that the coolant res. has 2 wholes melted it from the bike running so hot. does anyone have any idea what this could be.
Old 07-03-2011, 02:33 PM
Avi's Avatar
Avi
Avi is offline
what made the holes?
are they all the way through?
if they are leaking coolant obviously replace the tank.
on the good side,if the coolant leaked from the tank the engine is fine if it doesn't overheat.
the only odd thing is how the **** did those holes got there.
try to trace the coolant on the engine. even just which side/area will help point it's origin.
and while you are at this check the coolant level in the radiator to make sure it's full.
Old 07-03-2011, 03:45 PM
kapsiak's Avatar
the wholes got there from the plastic tank melt, and yes they did go all the way throw. and i see on the exhaust rite below the tank where the coolant leak onto it.
Old 07-03-2011, 04:24 PM
stampern's Avatar
Almost sounds like it just got way to hot. I personally don't let my bike idle in one place very long. They just don't have cooling systems like cars.
Old 07-03-2011, 05:55 PM
kapsiak's Avatar
You think once I replace the tank and change the oil and colant everything will be fine?
Old 07-03-2011, 06:48 PM
stampern's Avatar
tank and coolant for sure. Oil probably won't make much difference as far as cooling goes. Might double check your radiator cap too.
Old 07-03-2011, 06:55 PM
kapsiak's Avatar
well the oil light was on when this happening. when i saw that i shut the bike off as fast as i could
Old 07-03-2011, 08:04 PM
stampern's Avatar
Weird. Is you oil low?
Old 07-03-2011, 10:17 PM
kapsiak's Avatar
It is now for some reason
Old 07-03-2011, 10:36 PM
Avi's Avatar
Avi
Avi is offline
find where the oil is coming from. if you must take off all the fairing around the engine.
my guess will be the water pump on the left side.
also look inside the radiator if you can see some oil floating there.
are you sure the coolant on the floor had oil mixed in?
if you don't find the oil leak at all, my guess would be a head gasket breached and oil and coolant leaked into the combustion chambers. when they ran low the engine overheated.
that is a worst case scenario, so don't panic yet. find where they are coming from, and if you must clean the engine. if you still havent found any thing after you let it sit clean for a day fill again everything up and start the engine for a while.
just make sure it doesn't overheat or anything.
hopefully after this you will spot the source of the leak.
Quick Reply: leaking coolant
