Originally Posted by stampern
(Post 1072206)
I had the upgraded honda finned one - didn't hold my voltage high enough. I had to go to the new mosfet r/r to get my voltages higher. Helped out tons. My bike used to barely idle if not die when the fan would kick on. Now it just has a slight miss every now and then. Very happy with it. Going to upgrade the wiring to see if I can get a bit more juice out of it. I'm holding 12.9v at idle with the cooling fan on.
I agree with you. I checked the other components and all appear to be running within their limits. After doing a bunch of reading, the older r/r just aren't very power efficient (not just with our cbr's, but other bikes as well). Decided to upgrade cause the new chipset loses less power to heat than the older r/r's do, so I figured the least amount of power I can "waste" in my charging system the better. So far so good, but I'm not going to stop there.
Originally Posted by gotcbr
(Post 1072205)
Any developments?
I almost asked at first about your vacuum hoses. Would be interested to know how it runs w/ the stock setup connected. I rode to work today, and something's amok elsewhere. First of all, my tank bag was stolen last night, but that's not the point of this story. When I rode the bike home from the shop Friday evening, I had forgot my earplugs, so all I could hear was wind. Today (first ride since), I hear very noticeable gear whine. That has nothing to do with any of the service work unless a quantity of carb cleaner or fuel got dumped into the cylinder(s). Oil level remains fine, and it doesn't look milky. I also ran out of gas on the freeway today at ~117F, and had to push it a ways to get to fuel. Thankfully, a good Samaritan named Lorin bailed me out by giving me his only $7 in cash (no wallet on account of stolen tank bag, etc.). As a result of all these things, I parked the bike elsewhere and it'll stay there until I can change the oil & filter (again; just did it a couple hundred miles ago), and try to figure out what's up overall. |
Sorry to hear about your stolen tank bag. That really stinks. I had a bike stolen once & never got it back. I know that feeling.
Did you run out of fuel due to malfunctioning fuel light or just an oversight? Either way, sorry that happened to you as well. I'm afraid there isn't going to be quick or simple reply to the problem(s). There's obviously some issues. However, that doesn't mean they aren't fixable. Hang in there...all around. |
No idea why I ran out of gas. Yesterday was the first time I've ever seen the low fuel light; thought it didn't work, as I've put 4.5+ gallons in before without having seen the light. I drive by the odometer. I can make 3 round trips (work and back) in just under 210 miles, and it's time to refuel. Trip meter is reset and mpg calculated each fill-up. Trip meter said ~102 miles when she died. All I can think is that the mechanic work somehow reset the "A" trip meter. Disconnected wires womewhere? No idea.
Hopefully I'll figure out what's causing the idle misfire some time, and hopefully it won't prevent me licensing the bike if I don't. |
Originally Posted by MZ5
(Post 1072599)
Yep, when you disconnect the battery or if battery dies, the trip will zero out.
(Post 1072599)
Well, that probably explains what went wrong with me running out of fuel (the battery disconnection). I was _sure_ I'd disconnected the batt before and not lost the trip meter, but now that I think about it, that's probably not true. I've only disconnected the batt once that I can recall; normally my simply/routine maintenance work doesn't need me to disconnect it.
What kinda mpg do you see with your F4, gotcbr? I get right at 50mpg now, purely commuting (nealy all freeway). I used to get 54mpg when my commute was 40 - 60, but I surely can't complain about 50mpg at 65-80 mph on a 100hp sport bike! :) |
As of my last gas receipt... (did all these miles in one day on a fun ride...some spirited twisties, some hwy, some city)
I had a 155 odo reading & took on 3.25 gal. Tank capacity = 4.76 gal That's a dif of 1.51 gal MPG to the 155 mi mark = 47.69 For normal everyday hwy commuting, my experience is like yours - higher MPG than the above. However, the above shows how good the F4 is on MPG given a combo of dif types of riding on a single tank. An even better indicator is to calculate your MPG over 3 fill-ups. |
Cool! I'm a little particular about mpg calcs. I do them every fill-up on every vehicle I own. :)
Maybe I'll do a test some day: Tucked mpg vs. 'regular' commute posture. :) |
^ Used to be that way. ;-)
I should mention that elevation & temperature conditions will also effect on MPG. My above mentioned ride went from an elevation of approx 300 ft above sea level to over 5,000 ft. :-) And, temps from low 60s to over 100. :O |
