How to test fuel pump (startng issues)
Got the new pump installed and have a couple of new questions.
Is the pump supposed to make a noise every time you flip the ignition switch? One time I did that it made a vibrating noise for like a second and I noticed the fuel level in the filter went down (tank was off). This seems like a positive thing no? But why is it only every once in a while that it does this? Wiring fault?
How do the fuel pump transfer relay and fuel cutoff relay operate as far as which signal switches them on and off? Does the cutoff relay need a constant signal to allow the fuel pump to work? Maybe that could be my issue.
Good News! (James May voice)
I made a very simple DIY manometer/carb synch tool. I was putting it off because I wasn't sure if it was worth going to the store to even try but I was just being lazy. Turns out it was very very simple. Bought piece of 1/8" clear hose from home depot, 2 3/16" to 3/16" plastic hose connectors and a tiny bottle of 2 cycle engine oil from autozone. In total it was between $10 and $15.
Once I hooked it all up I was on my way. Cylinders 3 and 4 were waaay off. I evened them out, moved to 1 and 2 which were only slightly off and then 2 and 3 were only slightly off as well. There is a noticeable difference in the idle and I think I may have solved part of my problem. After that the idle was kinda high so I adjusted the throttle stop so it idles around 1300-1400 RPM which is the spec in the manual.
Now I just need to find out why it doesn't want to run with the fuel pump hooked up and only run when bypassed .I synched the carbs with the pump bypassed because it is the only way that I can get it to start.
The usual problem with the fuel pumps is the electrical contacts in the end of it.
The pump part is very reliable.
You can buy replacement contacts for the fuel pumps at much less money than a new pump and it only takes 10 mins to fit them with a little soldering.
See here - Honda CBR 600 F PC35 2000 Fuel Pump Repair Kit Petrol Points Switch | eBay
Im doubting on ordering the contacts or buying a new pump.
Contacts would mean u$d 30
and for a pump they have asked me u$d 100.
Help, please.
