How do you pick a rear stand?
Old 01-10-2009, 07:27 AM
cwmc29's Avatar
Default RE: How do you pick a rear stand?
ORIGINAL: platnumbob
Do most people use these axel spools with their F4? The problem I am forseeing is when I have to replace my rear tire/ and or brakes......how am I going to remove the wheel if the stand is suported by the axel?
The problem with drilling is possible weakening of the swingarm, has anyone had a problem there?
I have the axel spools that go into the axle. When I need to work on the rear wheal, I just switch over the stand and put it up on the swingarm. I find the axle spools work fine. I have used them for the past two years with no issue.
Here is a link to the axel spool question.
https://cbrforum.com/m_733431/tm.htm
  #32
Old 01-10-2009, 05:18 PM
TikkiTakki's Avatar
ORIGINAL: cwmc29
Sweet, expensive but I got a stand for Xmas and cannot use it. I just bought these so hope they are worth the 35 bucks!
  #33
Old 01-10-2009, 10:01 PM
platnumbob's Avatar
I ended up getting a stand that has both the platform lifts and spool option. I am much happier with this stand....I will use the platforms for now and if I ever change bikes I can always switch the stand over.
NEPAF4i
03-18-2014 05:21 PM
bluej511
01-11-2008 11:03 PM
Dice
02-01-2006 11:38 AM
Quick Reply: How do you pick a rear stand?
