How to do a wheelie
I am -1 +2 and I clutch 2nd all day
For 2nd I will give it about 3/4 throttle at about 4-5,000 RPM as the RPM is passing 6,000 I will clutch it. it comes up great.
3rd is a little more difficult same idea but give it full throttle somewhere between 6-7,000 Rpm I will clutch it.
I'm not sure what altitude you are at but I am at 4,500 ft and clutching 3rd is a pain in the a$$ at sea level I can do it all day.
I dropped one tooth in the front with the RK quick accel kit and 2nd gear clutch ups are pretty easy, but I hate doing them because I know its destroying the clutch. Otherwise just get going in 2nd around 7000, pin it then let off and preload the front forks while standing up and it should come up.
I'd rather replace clutch fibers, than chain and sprockets....
