Hiss Immobiliser Question
#21
Right matey, you will have to check the connection of the new ignition switch ,to see which wire receives 12v to the Blue/Orange wire harness side, with ignition off back probe the other connectors in the ignition connector with your multimeter , then turn ignition on and see which other wire gives you 12v, was the Ignition Switch from China as they dont usually align straight off
#22
#23
Right matey ,had to read through your posts to see where we are up to, so as your bike is running and its just the fan thats not cutting in we have to find the other live 12v for the fan, so at the ignition connector to the harness we know that the Red wire and Red/Black wires coming from the harness to the ignition connector are in the correct positions, just need to find which of the other 2 wires from the new ignition switch is carrying 12v and change positions in the connector to marry it up to the Blue/Orange wire in the harness side. think we have it there
#24
#25
#26
I fiddled around with the ignition wires using a multimeter and I believe I now have it wired correctly as everything is working, however, my battery is goosed, not holding a charge even off the mains charger, I had to jump start it off my car battery and the bike starts and runs fine, have 14 volts at battery while jump leads are connected and everything working but I never got to test fan, it does however have 14 volts running to it according to multimeter, thing is once I disconnect jump leads the bikes revs drop and will cut out if I switch on anything Electrical, such as the headlight , all it has across terminals is 2 volts so I need a new battery.
Question.
Should the bike be able to idle with no battery or dead battery, should the altenator not provide enough current to run the bike once its started and should there not be 12 volts + at battery terminals when bikes running?
#27
#28
Excellent, hopefully so with new battery everything should be sweet 👍
#29
