header gaskets
header gaskets
Hi Guys,
I have a cbr 6 Fx (F4 for us market) and I am in the process of replacing the header pipes with some stainless ones. After much trouble I finally took off all the nuts and some of the stud bolts, and removed the old rusty headers. Now I know that there are some old gaskets in the ports so I grabbed a flat headed screw driver and started removing what I thought was an old gasket but it won’t come off, I went all around the inside of that port and pried the thing off but it’s still stuck in there. Is there anything else that I might be damaging? Or is it normal for old Gaskets to stick that bad? What I pulled is thin (tough) metal with some type of brittle material inside.
What I want to know is whether I am scraping an old gasket or some bits from the port itself?
Appreciate any help or advice. Will try to get some photos of the thing when it’s daylight.
Cheers
Az
Cheers
Az
cBrentb
08-07-2013 03:02 AM
