Fuel pump needed or not?
No pics but re-piping is very easy.
1 Pipe from fuel tap to a fuel filter ( The fuel filter straps on to the bracket for the tickover adjuster )
1 Pipe from the fuel filter in to fuel pump.
1 Pipe from fuel pump up to carbs - t piece to feed both carb inlets.
Just make sure you identify the INLET and OUTLET correctly on the fuel filter and the fuel pump
Yep - basic piping - the pump shuts down when up to pressure - no vents or evap cans in the system.
I did and thank you fr your input, I've just had a few problems with the bike and still haveing a few and all of them seems to be a fuel delivery issues and seem to happen after about 150 miles or so, what's the normal range on one of these?
Could be a blocked breather tube to the fuel tank.
