fuel pump failure :(
Ive ran my 93 blade like this for a week and it works a treat BUT rememember to keep the bike full of petrol as you will have no reserve. This is becuase the pump is only there becuase the carbs are higher than the bottom of the tank and is needed for a small presure boost to compensate. Removing the pump makes the last of the fuel unavailable.not fun to find this out on a wet bypass in rush hour.
Since buying my aftermarket fuel pump i continued looking into alternative fuel pumps and came across this on "Horizons Unlimited" regarding Honda Africa Twin fuel problems -
Africa Twin Fuel Pump - Horizons Unlimited - The HUBB
and on checking out Facet Fuel pumps in the UK I found a site selling for very reasonable prices which should work on our bikes as the pressure appears to be about right
Facet Posi-Flow Electric Fuel Pump 1 5-4 00psi 60104 - special offer with straight unions
Again this may save a lot of money for anyone into working on the bike themselves and I have saved the paged and will inquire to get one as a spare for the future
The Facet 60104 isn't the one you want. Facet 40171 (made by purolator) is the correct pump for the F4 as it has the proper check valves to stop fuel from flowing into and flooding the carbs if you forget to shut off the petcock. It also flows at the correct 2-3.5 psi so it's not overpressuring the carbs. The best part is it's under $50 so half the cost of oem and it's solid state..no points to fail. I've had one in my F4 for 2 years and no problems at all. She runs better with the Facet pump than she ever did with hondas.
Kopi Ko
10-01-2019 08:29 AM
