Fuel Cut off relay - purpose??
i had to replace the fuel cut off relay when my fuel pump went out and i found out the PO put a fuel pump on it from Advance Auto. i'm pretty sure it's just on our bikes to make the wiring more complicated. haha, i really am not sure exactly what it does, but i do know it kept that Advance Auto fuel pump from burning up my fuel pump relay or any wires.
sorry i'm not much help. i'd like to know exactly what it does as well.
"The ECM controls power to the fuel pump by switching the fuel cut relay on or off."
That's directly out of Honda's "Fuel Induction" Resource Guide.
The relay is nothing but an on and off switch controlled by the ECM. Does the same exact thing for Carbed bikes and Fi model bikes.
99' and 00' F4's don't have a Bank Angle sensor which is what you described. Only the Fi models have those. And they are located under the front fairing near the nose.
"fuel cut relay" is bad translation from Japanese. Just "fuel pump relay" and it makes much more sense.
Unlike EFI system, the fuel-pump is controlled by fuel-pump relay with ignition pulses. At idle and low speed, there's few pulses-per-second and just little bit of petrol is pumped. At higher RPMs, there's more ignition pulses-per-second and pump is pulsed more to deliver more fuel to match demands. Ingenious solution to vary fuel-volume based upon load.
Clicking of fuel-pump is it being pulsed by ignition pulses. Rev up engine and you'll hear clicking increase. Also look onto "solid state pump upgrade", which converts mechanical clicker at bottom of pump with electronic version. Like going from mechanical points ignition to electronic.
